Boiler Water Increases - no automatic feed
Eric Tardif
Eric Tardif Member Posts: 38
The boiler was designed as oil, forced hot water. It was converted to gas using a Wayne P265 oil-to-gas burner gun. Then the heater man converted the boiler to a steam system.
No domestic hot water - we use a gas hot water tank.
No tankless coil is inside the boiler.
The manual feed valve is at least 30 years old.
Could I just change the rubber washer in the manual feed?
  • Eric Tardif
    How
    does the water rise in the site glass when I didn't manual add water?!! Some times there's gallons and gallons that come out - even when the boiler was cold for a week! There's no other water flow intake except the manual feed. The plumber doesn't believe me or doesn't have an answer. I am stumped.
  • Overfill
    Is this oil or gas?
    Do you use it to produce your domestic hot water?
    Is there a tankless coil inside the boiler?
    How old is the manual feed valve for the boiler?
    Ed Carey
  • Bruce Stevens
    Bruce Stevens Member Posts: 133
    Three most common problems
    1 Manual feed leaking by
    2 Tankless coil leaking
    3 Coil in Hot Water Maker leaking
  • Eric Tardif
    Bruce:
    The manual feed may be leaking but I checked the water meter for any leaks when everything was off. Nothing registered as moving.
    There's no tankless coil.
    We use a gas hot water heater tank.
    It must be the manual feed somehow.
