Boiler Water Increases - no automatic feed
Eric Tardif
Member Posts: 38
The boiler was designed as oil, forced hot water. It was converted to gas using a Wayne P265 oil-to-gas burner gun. Then the heater man converted the boiler to a steam system.
No domestic hot water - we use a gas hot water tank.
No tankless coil is inside the boiler.
The manual feed valve is at least 30 years old.
Could I just change the rubber washer in the manual feed?
How
does the water rise in the site glass when I didn't manual add water?!! Some times there's gallons and gallons that come out - even when the boiler was cold for a week! There's no other water flow intake except the manual feed. The plumber doesn't believe me or doesn't have an answer. I am stumped.0 -
Overfill
Is this oil or gas?
Do you use it to produce your domestic hot water?
Is there a tankless coil inside the boiler?
How old is the manual feed valve for the boiler?
Ed Carey0 -
Three most common problems
1 Manual feed leaking by
2 Tankless coil leaking
3 Coil in Hot Water Maker leaking0 -
Bruce:
The manual feed may be leaking but I checked the water meter for any leaks when everything was off. Nothing registered as moving.
There's no tankless coil.
We use a gas hot water heater tank.
It must be the manual feed somehow.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
