HEAT LOSS quick calc.
hot_rod
hot_rod Member Posts: 27,412
is a very simple and quick software program. It also allows you to build walls and floors of various r values.
www.hydronicpros.com for a look.
hr
  • JBW_2
    JBW_2 Member Posts: 67
    heat loss
    I know that all you guys are gonna scold me for this one.
    Looking for a quick 'rule of thumb' calculation for heat loss on an old home. Any resources?
    JBW
  • Jack Hinz
    Jack Hinz Member Posts: 7
    Quick Calc
  • Big Ed_4
    Big Ed_4 Member Posts: 3,529
    Burnham
    Burnham's pocket reference book has a low tech heat loss cal good for a salesmen.
  • John_Barba
    John_Barba Member Posts: 166
    Heat loss
    We teach a basic heat loss calculation at our factory training program at Taco. There's a simple pencil and paper method taught in "The Compleat Boiler Room," along with a more in-depth program using laptop computers and Taco's FloPro Designer software in "Hydronic Heat Loss & Design." These classes are open only to the trade. Go to taco-hvac.com/flopro for more info.
    The only rule of thumb I can offer you is "do the math."
    JMB
  • Brad White_185
    Brad White_185 Member Posts: 265
    Good, Fast or Cheap
    Pick any two.
    Drop me a line off-line and I can send you a spreadsheet I developed. It does require some knowledge of where the factors are derived.
  • Boilerpro_5
    Boilerpro_5 Member Posts: 407
    A resource
    Weil Mclain use to have a easy to use method that was based on a chart they developed. Unfortunately, the wholesalers and reps in my area tell contractors not to use it and base sizing on installed radiation for hot water systems, typicaly 150 to 200 btu/EDR. Oh well......
    Boilerpro
