WATER TO WATER HEAT PUMPS
jp_2
Member Posts: 1,935
the DEQ has ok'd this? any chance a leak can contaminate the pond?
Heat Pumps
How much polyprop tubing should I submerge in a pond per ton of cooling? I am in mid-Michigan.0 -
I'd be,,,
following the manufacturer's instructions on that if I were you.0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
