WATER TO WATER HEAT PUMPS
jp_2
jp_2 Member Posts: 1,935
the DEQ has ok'd this? any chance a leak can contaminate the pond?
  • Mike LeFevre
    Mike LeFevre Member Posts: 1
    Heat Pumps
    How much polyprop tubing should I submerge in a pond per ton of cooling? I am in mid-Michigan.
  • I'd be,,,
    following the manufacturer's instructions on that if I were you. ;)
