ID glycol type?
Timco
I am looking for a testing agency to tell me if a system has ethyl or propyl type glycol. I posted this before but did not flag it and now need to know...a ton of it leaked out a driveway leak and did not kill the lawn if that says anything...
Thanks, Tim
Thanks, Tim
Just a guy running some pipes.
HEY TIM!
Have`nt seen you in awhile, hope things are going OK!
Is there a poison control center in this area?, perhaps they could help.
This from a Canadian of course ;-)
Dave0 -
Oh, I'm here man! Raining for weeks now so not much fly fishing...
I was considering using my wife's lab and taking the solution to it's freezing point to see where it freezes. My tester tells me it's freeze point but I don't know which scale to use. (sight type tester, forgot name) Would poison control tell you if it is poisonous or not? I would really like to just send it to a lab...
TimJust a guy running some pipes.0 -
OK Tim,
I thought you were looking into the poisonous issue.
I`m not sure how to tell which is which myself, but poison is poison and a lab will tell you that.
Sorry I couldn`t be of more help.
Too bad about the fishin!
BTW-What ever became of your big move?
Dave0 -
Dow or Nobel
have labs to test that. What about the U of U ?
hrBob "hot rod" Rohr
Tim-
You might call Rhomar.
http://www.rhomarwater.com
I called them last year with some questions on boiler water and they were very helpful. They have water testing services and could probably test it for you or tell you how it needs to be tested.
- Rod0 -
glycol test
see our website www.rhomarwater.com printout the water analysis test form, tell us what to test for and mail it with a "clean "water bottle full of the fluid( approx 1 pt). I think the lab charges about $20.00 for the test.0 -
I may be wrong on this issue, but I think ethylene gycol is the nasty one and propylene gycol is actually the biologically friendly one. If ingested, the ethylene can do liver damage at lower concentrations. Both have a very high basic oxygen demand (BOD) so environmentally the problem would be if it go into a stream. It could strip the stream of oxygen and kill aquatics. If it got into a sewer, it could show up as a slug in the treatmnt plant and kill the "bugs". However, they both "burn out" faily quickly in the presence of organics (like a lawn)and I'd oubt if there would be any residual concerns after a few days in this weather.0 -
tester
Hey Tim, I believe they make a tester that can tell you which style of glycol you have by the s.g. of the fluid, I know McmasterCarr sells different kinds of Refractometers check out their website, if you use a Water Treatment Vendor or know someone that does in a commericial building their Treatment Vendor would be able to check it out for you, if you are close to Manhattan NYC I can have my Vendor check it out for you.0 -
Thanks for the suggestions. I will make a few calls but will likely send it to Rhomar to git r' done. I am in SLC, UT where it has rained for weeks. No sprinklers for weeks and mushrooms in the lawn...
Mushrooms
Better play it safe and send those mushrooms to me for evaluation.0
- 133 Chimneys & Flues
