steam pipe leak
Kevinj_3
Kevinj_3 Member Posts: 27
The proper way would be to cut out the offending piece of pipe and replace it.
Kevin
  • GenoC
    GenoC Member Posts: 8
    steam pipe leak
    Simple problem. Leak on 4" T threads. Last time used lead to seal threads. Any other ideas for a fix on a pipe leaking water from a steam system. As always, Thank you in advance. Geno C
