steam pipe leak
Kevinj_3
Member Posts: 27
The proper way would be to cut out the offending piece of pipe and replace it.
Kevin
Kevin
steam pipe leak
Simple problem. Leak on 4" T threads. Last time used lead to seal threads. Any other ideas for a fix on a pipe leaking water from a steam system. As always, Thank you in advance. Geno C0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
