double tapped bushing
kpc_14
Member Posts: 38
where I can get 1 ..1 x1/2x1/2"double tapped bushing...supply houses around here don't have any...ty,kpc
Try google
I googled "doube tapped bushing" and came up with quite a list. Check it out. I usually try to always buy from local supply houses, but with something special like this, the internet is your friend. Saves alot of driving around, too.0 -
I did...
a few manufact. ..if I want to buy 100.0 -
That is a strange and appears infrequently used size.
Most oil is 1-1/2-2"
curious, what do you use 1" for?0 -
it's the bottom...
bung of a radiator.0 -
A bung is a stopper, but why then do you need the double tapped threads on the inside also then?
internal risor, something I'm missing?
Interested, please explain0 -
HDE, glad it wasn't just me thinking that to
kpc, where are you? I know our supply house has all sizes in stock0 -
I am in New Hampshire...
This is a older steam radiator that is 6' long. It has 2 available tapping on the right side. I need to convert this to hot water...if I dont add a 71" x 1/2" piece of copper to one of the tappings the water will short cycle back w/o getting all the way through...the bushing will allow me to do this...kpc0 -
I have used a brass reducing bushing for this purpose some come with a recess that will accept 1/2 copper pipe on the inside to solder. Im sure 5' would be long enough depending on the direction of flow.
hope this helps0 -
heres a #
call South Shore Supply in Brockton MA @ 508.588.3600 with a credit card # they will ship you (1) ups0 -
Machine shop
KPC, how about you buy a regular bushing and have a machine shop thread the back side. I was a machinist before getting in the trades and can tell you it would be a very simple job and should be pretty cheap.0
- 50 Industry Classes
