Condensing Boilers
Tim Doran_4
Tim Doran_4 Member Posts: 138
There is an issue with an incorrectly sized clamp and/or hose on a certain run of units. HTP can provide a serial number range if you need it. The clamp cuts through the hose which then seperates from the boiler. This creates a breech in the heat exchanger on the positive pressure side of things which then dumps Co into the structure. I have spent over a week of labor going back and checking all of the units I have installed and checking for properly installed and functional Co detectors to cover my backside. I am still uneasy about leaving these units installed but can't afford to remove them all at my own expense.
Tim D.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=515&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
