double tapped bushing
kpc_14
kpc_14 Member Posts: 38
where I can get 1 ..1 x1/2x1/2"double tapped bushing...supply houses around here don't have any...ty,kpc
  • MIke_Jonas
    MIke_Jonas Member Posts: 202
    Try google
    I googled "doube tapped bushing" and came up with quite a list. Check it out. I usually try to always buy from local supply houses, but with something special like this, the internet is your friend. Saves alot of driving around, too.
  • kpc_14
    I did...
    a few manufact. ..if I want to buy 100.
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    That is a strange and appears infrequently used size.
    Most oil is 1-1/2-2"
    curious, what do you use 1" for?
  • kpc_14
    it's the bottom...
    bung of a radiator.
    A bung is a stopper, but why then do you need the double tapped threads on the inside also then?
    internal risor, something I'm missing?
    Interested, please explain
  • John@Reliable_14
    John@Reliable_14 Member Posts: 171
    HDE, glad it wasn't just me thinking that to
    kpc, where are you? I know our supply house has all sizes in stock
  • kpc_14
    I am in New Hampshire...
    This is a older steam radiator that is 6' long. It has 2 available tapping on the right side. I need to convert this to hot water...if I dont add a 71" x 1/2" piece of copper to one of the tappings the water will short cycle back w/o getting all the way through...the bushing will allow me to do this...kpc
  • Brendan_4
    Brendan_4 Member Posts: 12
    I have used a brass reducing bushing for this purpose some come with a recess that will accept 1/2 copper pipe on the inside to solder. Im sure 5' would be long enough depending on the direction of flow.
    hope this helps
  • John@Reliable_14
    heres a #
    call South Shore Supply in Brockton MA @ 508.588.3600 with a credit card # they will ship you (1) ups
  • Rich L.
    Rich L. Member Posts: 414
    Machine shop
    KPC, how about you buy a regular bushing and have a machine shop thread the back side. I was a machinist before getting in the trades and can tell you it would be a very simple job and should be pretty cheap.
