clean burn furnace
you could most likey get away with one just after filter/strainer at tank but thier's has a strainer too. Also check on line for parts, if you want to put one per spec's. One big factory rep. is in Greenfield MA and ships UPS P.S. I don't think a "tigerloop" can be used on waste oil.
  • Glen
    Glen Member Posts: 854
    foot valve req'd?
    The original installer neglected to install the foot valve in the oil supply tank - which has lead to continual drain backs. Will a swing check installed vertically work? All my suppliers are at a loss when I inquire re a foot valve for an oil tank. Other options?
  • ed wallace
    ed wallace Member Posts: 1,612
    cleanburn
    doesnt the clean burn come with its own tank? or is it useing an unerground supply tank? if single pipe install a tigerloop
  • Glen
    above ground supply -
    but the supply pump is mid way to burner, needs to pull 8 feet up from tank and then push another 12 vertical to burner. It is single pipe. Just thinking that a foot valve would eliminate the problem.
  • Maine Ken
    Maine Ken Member Posts: 531
    Dirigo Waste Oil
    92 College Ave
    Waterville, ME 04901
    SERVING MAINE & NEW HAMPSHIRE
    (888) 398 - 0881
