clean burn furnace
John@Reliable_14
Member Posts: 171
you could most likey get away with one just after filter/strainer at tank but thier's has a strainer too. Also check on line for parts, if you want to put one per spec's. One big factory rep. is in Greenfield MA and ships UPS P.S. I don't think a "tigerloop" can be used on waste oil.
foot valve req'd?
The original installer neglected to install the foot valve in the oil supply tank - which has lead to continual drain backs. Will a swing check installed vertically work? All my suppliers are at a loss when I inquire re a foot valve for an oil tank. Other options?0 -
cleanburn
doesnt the clean burn come with its own tank? or is it useing an unerground supply tank? if single pipe install a tigerloop0 -
above ground supply -
but the supply pump is mid way to burner, needs to pull 8 feet up from tank and then push another 12 vertical to burner. It is single pipe. Just thinking that a foot valve would eliminate the problem.0 -
Dirigo Waste Oil
92 College Ave
Waterville, ME 04901
SERVING MAINE & NEW HAMPSHIRE
(888) 398 - 0881
- 87.5K THE MAIN WALL
- 118 Geothermal
- 394 Solar
- 15.9K Strictly Steam
- 50 Industry Classes
