Estimation Software Preferences (The Youngster)
Josh_10
Member Posts: 786
What do you guys think about Maxwell?
Just curious what types of estimation software others are using. How friendly is it to Hydronics?
Thanks,
Josh0 -
the best one i have found is my brain.com
I could not help it but I sometimes find software to be a lazy way out of using my brain. Tim
Quite true. I have a distinct accuracy problem with my brain however when the project exceeds 5 or 6 weeks length.0 -
I've often wondered what
people used to estimate. I made up my own spread sheet years ago, but have always thought, there must be a better way. Watching with interest. WW
Josh,
I have used a system called Wendes for about ten years now and would not change to anything else.
I was one of their first plumbing system users and helped them with feed back the first couple of years.
I only use the plumbing/piping portion but they also have a duct work sytem that we used to use when still doing HVAC which we got out of six/seven years ago.
I have bid around 350 million dollars in those years and landed around 23%
I am on vacation, away from the office and will be back next week if you would like more information but you could
Google them to get a contact.
I have had few problems with the system over the years and when I did they responded quickly and got me going even at times taking over my computer from Chicago while I watched the mouse move across the screen.
Good luck,
Jack0 -
E Z Heat loss
Jerry and I used this program for years before and after they added radiant calculations and always had real good luck with it. Don't know if it exists still
Maybe I should tell you guys where I am going with this. We are currently working off of spreadsheets but need to do estimates a little quicker as we expand.
I am willing to make a significant investment if it's worth it. I need something with hydronic and sheet metal. Sheet metal seems easy but were having trouble finding a program with hydronic manifolds and room to room pex estimations.
- 50 Industry Classes
