Please read this regarding Bruce Marshall (Dan H.)
ScottMP
ScottMP Member Posts: 5,882
Glad to here its been worked out.
Go PATS
Scott
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=237&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    There's been some confusion in some of the posts.
    Bruce Marshall is my friend for more than 20 years and he posts here under his full name.
    Bruce M is Bruce Mandell and he posts under the nickname, "Bruce M."
    Both guys are entitled to post but some people are confusing the two men, mistakenly attributing Bruce M's comments to Bruce Marshall. This isn't the case and I just wanted to make that clear.
    Thanks.
    Retired and loving it.
  • Home Depot Employee
    Home Depot Employee Member Posts: 329
    Thanks Dan
    Although I figured that out early, perhaps others too.
    I was not going to believe that if "Bruce M" was Bruce Marshall, why he would promote other boiler lines.
    It’s all about reading between the lines and a simple assembly of a small puzzle.
  • Bruce M
    Bruce M Member Posts: 166
    Bruce M here to clarify
    In a previous thread I made it clear that I am not Bruce Marshall. I have also made it clear that I do not work for any boiler manufacturer or any other company that is selling HVAC products. Any opinions that I have posted are my own and I have never received money or any other form of compensation to say good or bad things about a product. In addition, I should say that I expect those who do work for a company to support that company and it's products. Any employer has the expectation of loyalty from it's employees.
  • DanHolohan
    Thanks, Bruce.
    There's been some confusion in the industry and I appreciate your post. Thanks.
  • Bruce Marshall
    Bruce Marshall Member Posts: 37
    Thanks Dan,
    It's like a mistake in a headline and a retraction on page 47. Everyone remembers the headline.
    Oh, and by the way GO PATS
    Bruce Marshall
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Bruceski...
    At least he's not here defending himself for a "headline"!!! Glad to see we CAN all get along.
    I must concur....GO PATS!!!
    Hey Bruce Marshall...when ya comin' back to the North Shore area? Chris
  • George_36
    George_36 Member Posts: 35
    One Pipe Steam Heat Problems
    I replaced an old steam valve beacuse steam was leaking from the valve, which stopped the leaking.
    Before I installed the new valve, I noticed thick black sediment in the steel pipe about 7 inches below.
    I did not want the problem to get worse, so I left it alone. Now with the new valve, it takes longer for that radiator to heat up.
    I poured two bottles of vinegar into the boiler to help clean the rust in the pipes. Did not notice much of a difference.
    George,
    Unless you are trying to figure out if your steam valve was installed by "Bruce Marshall" or "Bruce M", you may have posted to the wrong thread.
    Edward A. (Ed) Carey,
    I think the only Edward A. (Ed) Carey, too :)
