Copper Pipes / Steam Heat
NShak
NShak Member Posts: 38
Greetings All.
Bought our first home last June... this is obviously our first NJ winter with our own steam heat. Bought Dan's book, "We Got Steam Heat..." and have learned a lot. Also learning that we have issues w/ our 1-pipe system.
I have copper risers that connect to a copper header. This then attaches to a steel connector that then splits into two steel mains that feed the house. No main air vents or noticeable plugs near the ends of the mains.
I'm assuming I should have the copper pipes removed & replaced with steel. In the meantime, should I try to insulate them with fiberglass? In addition, some of the colder rooms/bathrooms have copper piped base boards. These definitely do not retain heat like our cast iron radiators. Should the copper baseboards be replaced with radiators or is there a better (smaller) alternative that will provide more long lasting heat?
I'm assuming I should have someone place main air vents prior to next winter, too.
Thanks in advance.
