Wells McLein Indirect Water Tank
Sheryl
Sheryl Member Posts: 3
Can anyone tell me how to flush out a Well McLein Indirect Water tank. It's designed with no drain pain and I'm constantly getting rusty water from my hot water lines.
Thank you.
  • Sheryl
    Wells McLen Indirect Water Tank
    Thank you.
  • Robert O'Connor_7
    Robert O'Connor_7 Member Posts: 688
    Sheryl..
    Does the domestic water have a recirculator on it?
    Robert O'Connor/NJ
  • The tank should
    have been installed w/ boiler drains in the hot & cold lines @ the top of the tank. Then you either syphon back thru the cold tap or hook a hose to both, fill thru the cold & drain off the hot side. The tank was made to flex, so no bottom drain.
