Wells McLein Indirect Water Tank
Sheryl
Member Posts: 3
Can anyone tell me how to flush out a Well McLein Indirect Water tank. It's designed with no drain pain and I'm constantly getting rusty water from my hot water lines.
Thank you.
Thank you.
Wells McLen Indirect Water Tank
Thank you.
Sheryl..
Does the domestic water have a recirculator on it?
Robert O'Connor/NJ0 -
The tank should
have been installed w/ boiler drains in the hot & cold lines @ the top of the tank. Then you either syphon back thru the cold tap or hook a hose to both, fill thru the cold & drain off the hot side. The tank was made to flex, so no bottom drain.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
