super stor on its side
adambuild
Member Posts: 422
Are you using as an indirect or buffer? I can't imagine it would work as an indirect!?
other than
the heat exchanger not being at the bottom the way its ment to be is their any thing wrong with this. I have never seen it but its seems like it would not hurt the tank.0 -
Not a great idea.
The less buoyant, heated water will want to rise to the top as the cold feeds into the bottom. You'd be missing a significant portion of your heat exchanger if the top and bottom are not where they're supposed to be.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Not sure about SuperStor
but the Phase 3 HL series could be laid down . I think it needed a special dip tube and you lost something like 30 percent of it's ratings , but it worked ( we did it once or twice ) .0 -
I will
Call the manufacturer and ask about capacity loss. I looked around after posting this and found that viesmann makes a 120 that is designed for horizontal. I think i will suggest this.0 -
if you need a better priced unit
crown had 2 horizontal units.0 -
Buderus and Viessmann
both make tanks designed to be installed horizontally.
I agree with others, a Super-Stor ( while a great tank ) is not designed to be installed on its side.
Scott
Crown makes a package where you can stack boiler on their horizontally designed indirect, great for tight spaces0
- 167 Indoor-Air Quality
