Upgrade toSmith Series 8 Steam Boiler
Paul_82
Member Posts: 7
I'm upgrading from a old oil-fired 1936 Americn Radiator Steam Boiler and a Electric Water Heater. After talking to several Contractors and feed back from different sources.
I have selected a oil-fired Smith Series-8(Model 8s3H)Steam Boiler, 83.4% AFUE,has a LIFETIME WARRANTY. With a SuperStor Ultra (SSU-45) Indirect Water Heater.
Can some of you experts comment on this hook up.
Thank You,Paul
Thank You,Paul
sounds like....
a winner to me. I have used many Smith 8 series....both steam and HW. Super stor is fine product too...I have one in my own home.Make sure it is cleaned and flusheed well after....kpc0 -
plan ahead
Install with strict adherence to factory piping diagrams & specs. consider drop header. discuss details with contractor before start of project. should go smooth as silk. note any existing defects in system before starting work. evaluate existing return system. might be good time to replace. good luck0 -
used many of them, use the Carlin burner.0
