Crane boiler replacement ( Ron Jr. )
bill_97
Member Posts: 172
Never seen a boiler so large in one of these homes . Usually it's just a tin can Federal . Another tight fit , this was not a fun rip out . Check out the mud in the bottom of the sections . Every one of them was plugged . You'd think this was pushing steam for 60 years .
Burnham V84 and 50 gallon stone lined indirect
Not our best work , but we covered the bases basically ..... We left enough room on the right to access the chimney and cleanouts . We kept the boiler and indirect apart enough to work on the multi relay . Circs on the returns again . No way around that unless we do a majr repipe in the basement . This was installed by Phil , Sal and myself . Kenny and Dave stopped by after they installed an oil tank . It was a real long day , non stop for almost 9 hours . No breakfast , no lunch , not even a cup o joe . We know it's not smart to work through lunch , but none of us wanted to be installing a boiler till 7 or 8 pm on a Friday . And these jobs always wind up being installed on a Friday .......0 -
Well done again !
Its a breath of fresh air to see the "ART FORM" hasn't died.
Tiger Loop ? Was it a long pull for the Riello ?
Has Extrol and ThermEx now turned the stickers the "right" way ? Don't want to start a war .
Thanks Ron
Ken ResnickThere was an error rendering this rich post.
nice job...
Ron. There was probably mud in there because there was so little flow w/ a boiler so big. Was there a bulkhead.....or do I know the answer already. kpc0 -
Ron, question
Don't you worry about shocking the boiler with multi zone like that? I would have thought primary secondary or maybe thermostatic bypass? Nice pipe work though.0 -
No worry
about shocking the boiler . 3 baseboard heat zone and the indirect on priority , there isn't much system water . And the aquastat has a low limit so the circs will not run a prolonged time with low temps .
If there was cast iron baseboard or freestanding rads we always pipe a bypass in .
Thanks Tim .0 -
Tigerloop
We had to reconnect to an overhead 1/4 inch oil line about 25 feet in length . Knowing how a Riello screams like a banshee on slightly higher than normal vacuum , we decided not to take a chance .
I've always been saying ..... let me apply the stickers after we install 'em .
Thanks alot Ken .0 -
Bulkhead ?
Actually these home aren't too bad to get equipment in and out of . 5 steps up into a nice sized living room and 15 feet to the garage .
We're kinda under the impression the system was losing water . These homes are notorious for slab leaks ( where they ran 3/4 copper to some baseboard ) . We jacked the pressure up but didn't see any drop . The feed valve is closed now , so time will tell .
Thanks Kevin .0 -
looks damn nice to me!!
another gorgeous Ron jr. job!! but hey- whats up with all the room to work? where's the tight closet you usually get stuck with? hehe
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"gwgillplumbingandheating.com
1/4\" oil line!
you must be joking....Must have broken into the icemaker tubing that day....kpc0 -
That's 1/4 inch OD
The most common size we see . Any new tank install gets 3/8 minimum .0 -
This was
just a little bit bigger than a closet . If there's gonna be a battle between servicability area and extra room for living space , we'll always lose .
Thanks Gerry .0 -
Great job0
- 167 Indoor-Air Quality
