Utica steam boiler call for heat problems
Dave_129
Dave_129 Member Posts: 5
Have a gas fired steam Utica boiler that cuts out a lot with no response when there is a call for heat. The usual quick fix that worked for the past year was to turn the power off/on which somehow started the system back up. This would last several weeks before having to do it again. This fix barely works anymore and has to be done numerous times before the boiler will kick in. I checked all electrical connections (transformer/low water cut off/ safety systems) with the green light lit for safe operation. I have also jumped the thermostat connections which rules out a faulty thermostat. I'm at a loss as to what the problem is. Any help greatly appreciated.....
Thanks
