oil tank foot valve
burnerman_2
Member Posts: 297
have u tried this but if u are losing ur prime u may have a loose brass nut or a bad flare most times after u bleed the air unless there is a loose fitting u should not need a check valve royboy
for a used oil storage tank
is there any commercially available and acceptable foot valves? 5/8 OD drop tube. trying to eliminate the drain back each time the burner (clean burn) shuts off.0 -
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
