Where is steam pressure measured
vacuum vents on the returns?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Where is steam pressure actually measured
    I'm new to this subject but also interested in it. I read in one of the posts that the Empire State building at a steam pressure of 1.5lbs to 2.0lbs. I'm curious to know if the steam pressure on a radiator on the 50th floor is at the same pressure as a radiator on the 5th floor. Second question. When using a vacuum system does this affect the overall pressure in the system.
    Jamie Hall Member Posts: 26,847
    the density
    of steam is very low -- comparable to air or less -- so it doesn't matter where in the system you measure it; you won't see the difference on any normal pressure gauge. So the answer to your first question is yes, so far as you can measure. The answer to the second question is no; all steam systems nowadays run at a very slight positive pressure. In the good old days, with coal furnaces, vacuum systems did run at small vacuum when the coal fire was damped down. Takes special vents to do that, and you don't need it with oil or gas.
  • Thank you Jamie
    That settles a question I've been thinking about.
  • RonWHC
    RonWHC Member Posts: 232
    Then how can numerous boilers
    I service (& have installed) have 1-3# pressure on the boilers & 1-8" of vacuum on the returns? Why do caps on radiator traps resist lifting when they are disassembled for repair?
    Vacuum systems still rock. And SUCK.
  • Frank.
    If you're asking me - those jobs all have vacuum pumps w/ 1/2 to 5 HP motors driving them. Threw in my 2 cents to show there are few absolutes. Particularly in what we do.
    Howsomever (sic). Hoffman still makes the #76 Vacuum Vent.
