smell with vaughn indirect???
hot_rod
Member Posts: 26,594
Vaughn top performer with smell
Has anyone experienced this? I recently(7/2/08) installed a 50 gallon vaughn top performer indirect. Today I went back to the customers house to run some eff.tests and the customer complained about a concrete or mortar smell from the water every time he takes a shower! As soon as he brought up the smell I figured it had something to do with the stone lining. I told him I would do some research on it and give him a call back. I've installed many of these tanks and have never heard such a thing. Just wondering if the stone is damaged in the tank?0 -
Did you try calling Vaughn to get there input? They would know best.0 -
Vaughn stone lined heater
Hi Rick,
A cursory Googling of 'Vaughn water heater smell' turned up this discussion on another forum:
http://www.plbg.com/forum/read.php?1,343575
Maybe that will help in some way?
HE0 -
smell
Could be the anode rod. Have had that issue with other products. YOu may have to change to another kind of rod. Check with the manufacturer
We had a few
customers complain about a smell and fine powder coating their dishes and showers . This is the Burnham version of the Vaughn . I'm guessing it's some byproduct of the cement lining . We had to drain the tanks , add some dishwasher soap , refill and heat up . Then we ran the hot side of the sink till it was clean of soap . On one job it took 2 visits to flush all the sediment out , so be patient . It will run clean .0 -
no anode ...
in a Vaughn.0 -
Another reason
Not to use this product... Poor performance, leaking gaskets, too heavy to move around.
Not my first, second or even third choice fro indirects.
Scott
