water stop plug
Jim Bennett
Jim Bennett Member Posts: 607
Done!
  • STEVE PAUL_3
    STEVE PAUL_3 Member Posts: 126
    water leak plug
    I am trying to locate a plug that can be inserted into a dripping water line to facilitate soldering. The plug is pushed into the pipe and swells when the water hits it. Then the joint is soldered. After the soldering is completed the area of the pipe that the plug is in is gently heated with the torch to disolve the plug. I have seen this product at trade shows but can not locate it in my area.
  • ed wallace
    ed wallace Member Posts: 1,612
    water plug
    any plumbing supply ouse should carry it dont know what its called but have seen it
  • bob young
    bob young Member Posts: 2,177
    GET A LOAF OF PUMPERNICKEL
  • Weezbo
    Weezbo Member Posts: 6,231
    i have a Jet Sweat i carry on my key fob with the Krypton Light beam and the Grundfos motor magnet:)
    however Bobs got good taste :) might wrap your mind around the thought ...it is quality :)
  • Bruce Stevens_2
    Bruce Stevens_2 Member Posts: 82
    Some of the
    water leaks I have stopped with my Sweat Jet would turn that loaf of Pumpernickle to mush in mear moments;-)
