water stop plug
Jim Bennett
Member Posts: 607
Done!
water leak plug
I am trying to locate a plug that can be inserted into a dripping water line to facilitate soldering. The plug is pushed into the pipe and swells when the water hits it. Then the joint is soldered. After the soldering is completed the area of the pipe that the plug is in is gently heated with the torch to disolve the plug. I have seen this product at trade shows but can not locate it in my area.0 -
water plug
any plumbing supply ouse should carry it dont know what its called but have seen it0 -
Jet-Swet
is what it's called. Go here:
www.brenelle.com/
GET A LOAF OF PUMPERNICKEL0 -
i have a Jet Sweat i carry on my key fob with the Krypton Light beam and the Grundfos motor magnet:)
however Bobs got good tastemight wrap your mind around the thought ...it is quality
Some of the
water leaks I have stopped with my Sweat Jet would turn that loaf of Pumpernickle to mush in mear moments;-)0
- 87K THE MAIN WALL
- 57 Biomass
- 115 Chimneys & Flues
- 5.7K Gas Heating
- 107 Geothermal
- 70 Pipe Deterioration
- 983 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
