where can I get cast iron hot water radiators
D107
Member Posts: 1,944
they make to size
Does anyone know where I can purchase cast iron hot water radiators? Have a house that 4 of them froze and split. They are all 20" +/- high, 5 1/4" deep and are 36" - 31 1/2" - 27" and 22 1/2" long. They have 1/2" tappings. Thanks for any help.0 -
You may find some,
at a local demolition contractors, some of those guys keep them to re-sell when they tear-down buildings.0 -
Burnham,
Still makes cast iron radiators in many forms and sizes.
Your local distributor can get what you need. Chris0 -
GOVERNALE. REASONABLE & GOOD.0 -
Looks like a Match
to the Burnham slenderized radiators, they make a 4 tube 19" high and a 4 or 6 tube 25" high in various section lengths, I just installed a few last week. Readily available from Burnham , I had mine in a week.0 -
CI Rad
Charlie , what part of the country are you in? I have several radiators. I am in CT.0 -
radiators
I sold a bunch of yhem to stanthejunkman.com
Kingston NY area he has a barn full
if they're used, have them pressure-tested before you buy
That's usually recommended on the Wall; I don't recall the required level of pressure test but you don't want to have to find out after install that they're leaking. Some companies certify they've been tested.
Good luck,
David0
- 167 Indoor-Air Quality
