Unions vs. Flange
Chips
Chips Member Posts: 33
Is there any difference or preference between using unions or flanges on a low pressure steam system?
Thanks
Chips
  • bob young
    bob young Member Posts: 2,177
    Use unions up to 2 " ips 2 1/2 " & larger use flanges
  • bill_97
    bill_97 Member Posts: 172
    Unions all the way
    to 4 inch for us . You have to be dead on , and I mean dead on , to line up flanges .
    I'm simply not that dead on to do it . Unions are a little more forgiving if the piping doesn't line up perfect .
    Longevity - I've seen both flanges and unions in service for many decades without leaking .
  • Craig_8
    Craig_8 Member Posts: 33
    "You have to be dead on , and I mean dead on , to line up flanges"
    try this trick next time you use a flange. line up 1 hole. drop a bolt in. now turn the flange with a pipe wrench untill the the rest of the bolts line up. the compound leverage creates an unbelievable amount of force that can pretty much line anything up.
    using this method i easily lined up a a 6" flange on a header that was off by 2 inches
  • bill_97
    Craig
    That is a good trick , I'll have to try that next time we use flanges . Swing joints probably make it even easier . I bet a union couldn't handle that amount of torque .
  • gerry gill
    gerry gill Member Posts: 3,084
    I'm in the Bob Young camp
    over two inches i like flanges..sometimes even two inch i'll use flanges..
    gwgillplumbingandheating.com
