Unions vs. Flange
Chips
Member Posts: 33
Is there any difference or preference between using unions or flanges on a low pressure steam system?
Chips
Chips
Use unions up to 2 " ips 2 1/2 " & larger use flanges0 -
Unions all the way
to 4 inch for us . You have to be dead on , and I mean dead on , to line up flanges .
I'm simply not that dead on to do it . Unions are a little more forgiving if the piping doesn't line up perfect .
Longevity - I've seen both flanges and unions in service for many decades without leaking .0 -
"You have to be dead on , and I mean dead on , to line up flanges"
try this trick next time you use a flange. line up 1 hole. drop a bolt in. now turn the flange with a pipe wrench untill the the rest of the bolts line up. the compound leverage creates an unbelievable amount of force that can pretty much line anything up.
using this method i easily lined up a a 6" flange on a header that was off by 2 inches0 -
Craig
That is a good trick , I'll have to try that next time we use flanges . Swing joints probably make it even easier . I bet a union couldn't handle that amount of torque .0 -
I'm in the Bob Young camp
over two inches i like flanges..sometimes even two inch i'll use flanges..
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 87.4K THE MAIN WALL
- 121 Chimneys & Flues
- 15.8K Strictly Steam
