Taco 241 SWETCHECK
Roland_4
Roland_4 Member Posts: 84
Thanks Bruce, is there a procedure for properly setting the adjustment knob? Roland....
  • Roland_4
    Taco 241 swetchek
    Hi All, There are two of these devices installed on my heating system. I checked the TACO website and can't seem to match up what I have with what's on their site. Does anyone have any info on these decvices? Most importantly, how does one adjust the thumbscrew at the top? Thanks,Roland
  • Flow check
    Roland that device is a flow check valve, used to prevent gravity circulation in your system. The knurled knob at the top is used to manually open the check.
  • Roland_4
    Taco 241
    Thanks Don, Which way does the knob operate? Screw it in to open or close? Thanks,Roland
  • Bruce Stevens_2
    Bruce Stevens_2 Member Posts: 82
    Screwed all the way down is closed
    up is open
  • Bruce Stevens_2
    just screw the knob down tight and tighten the
    brass nut it is just a packing nut so don't over do it just enough to keep from weeping water
  • Roland_4
    Taco 241
    Thanks Bruce.
  • Bruce Stevens_2
    Your welcome
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    The Taco 241 Flo-check valve is commonly used in a hot water system when zoning with circulators. The primary function is to prevent thermal siphoning. For your reference I attached the catalog data, and the instruction sheet. Hopefully this helps you.
    Joe Mattiello
    Taco Comfort Solutions
  • Roland_12
    Roland_12 Member Posts: 19
    Taco 241
    Thanks Joe, This is the information I need. Roland....
