Taco 241 SWETCHECK
Roland_4
Member Posts: 84
Thanks Bruce, is there a procedure for properly setting the adjustment knob? Roland....
Taco 241 swetchek
Hi All, There are two of these devices installed on my heating system. I checked the TACO website and can't seem to match up what I have with what's on their site. Does anyone have any info on these decvices? Most importantly, how does one adjust the thumbscrew at the top? Thanks,Roland0 -
Flow check
Roland that device is a flow check valve, used to prevent gravity circulation in your system. The knurled knob at the top is used to manually open the check.0 -
Taco 241
Thanks Don, Which way does the knob operate? Screw it in to open or close? Thanks,Roland0 -
Screwed all the way down is closed
up is open0 -
just screw the knob down tight and tighten the
brass nut it is just a packing nut so don't over do it just enough to keep from weeping water0 -
Taco 241
Thanks Bruce.0 -
Your welcome
The Taco 241 Flo-check valve is commonly used in a hot water system when zoning with circulators. The primary function is to prevent thermal siphoning. For your reference I attached the catalog data, and the instruction sheet. Hopefully this helps you.Joe Mattiello
Taco Comfort Solutions0 -
Taco 241
Thanks Joe, This is the information I need. Roland....0
