Outdoor Reset
tim smith
Member Posts: 2,886
outdoor reset also. I did not look at data sheet completely to see how far of a separation you can get between radiant floor injection and temp of boiler. Read data sheet further, if you have a boiler supply sensor wired to 356 you can reset boiler also. Tim
Outdoor Reset
Any suggestions on controls for OD reset? We have a 2 story house summer/winter hook up with hot water baseboard throughout except the kitchen which is radiant. The radiant is controlled by a Tekmar 356. We are going to replace the domestic coil with an indirect. Just wondering what the options are to control the BB along with outdoor reset. Thanks for any information.0 -
I series taco mix valve for the BB zone0 -
OD Reset
Thank you to all.0
- 167 Indoor-Air Quality
