Outdoor Reset
tim smith
Member Posts: 2,807
outdoor reset also. I did not look at data sheet completely to see how far of a separation you can get between radiant floor injection and temp of boiler. Read data sheet further, if you have a boiler supply sensor wired to 356 you can reset boiler also. Tim
Outdoor Reset
Any suggestions on controls for OD reset? We have a 2 story house summer/winter hook up with hot water baseboard throughout except the kitchen which is radiant. The radiant is controlled by a Tekmar 356. We are going to replace the domestic coil with an indirect. Just wondering what the options are to control the BB along with outdoor reset. Thanks for any information.0 -
I series taco mix valve for the BB zone0 -
OD Reset
Thank you to all.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
