Baseboard heat, low heat, some zones no heat
John_220
Member Posts: 2
Had one zone just wouldn't work. I have 3 thermostat controlled zones, white-rogers 1361-103 valves. Dial on valve would spin but usually would feel little to no heat on the pipe. Deciced to pull the valve apart. There was a lot of play in the action of the stem and I believe the motor was turning but the stem was not. I removed the stem and reinstalled the valve head until I get a replacement. Upon refilling, bleeding and restarting the system, the other zone were iffy until I raised the pressure to about 23psi. The circulating pump has also been doing some off and on humming as late. Is the pump probably going?
John
What kind of pump? Taco, B&G, 3piece?
Can you post any pics?
Dave0 -
Pump type
Pump type is Grundfos. I have already replaced it and have heat circulating well now. I do also have White-Rogers 1361-103 zone valves as well and one zone valve (although i haven't torn the others apart) has enough slop on the stem that I believe sometimes the motor spins but the valve stem does not, therefore limited to no heat in that zone. I have removed the stem for now until I get a replacement, so whenever one off the other 2 zones is on, that one warms as well. Should I tear apart the other valves and check? I have lived here 12 years and have no idea how long the unit has been here. Has been relatively maintenance free.
John0
- 167 Indoor-Air Quality
