Automatic water feeder not kicking in
kpc_12
Member Posts: 24
the power back on..right?
Hi! We had our boiler replaced about 2 months ago and just had an automatic water feeder installed about 2 weeks ago. Today it was pretty warm, so I turned the heat off. While it was off, I drained some of the water out to flush out any sediment in there. Now the automatic feeder isn't kicking in. The water level is about an inch below the min water level line and the low water cut off light was on, but now isn't. Any help?
auto water feed
make sure the valve after the auto water feed is open0 -
Make sure
the wiring in the LWCO is wired to the correct terminals, if the power and burner wires are backwards the feeder curcuiit will only call when power is missing from the switch if the feeder uses 120V from the LWCO0
- 167 Indoor-Air Quality
