Automatic water feeder not kicking in
kpc_12
kpc_12 Member Posts: 24
the power back on..right?
  • ak12
    ak12 Member Posts: 1
    Hi! We had our boiler replaced about 2 months ago and just had an automatic water feeder installed about 2 weeks ago. Today it was pretty warm, so I turned the heat off. While it was off, I drained some of the water out to flush out any sediment in there. Now the automatic feeder isn't kicking in. The water level is about an inch below the min water level line and the low water cut off light was on, but now isn't. Any help?
  • ed wallace
    ed wallace Member Posts: 1,612
    auto water feed
    make sure the valve after the auto water feed is open
  • Bruce Stevens_2
    Bruce Stevens_2 Member Posts: 82
    Make sure
    the wiring in the LWCO is wired to the correct terminals, if the power and burner wires are backwards the feeder curcuiit will only call when power is missing from the switch if the feeder uses 120V from the LWCO
