Tekmar RTU Type 307..............hb
........have one somewhere on a shelf in the back room? This is circa late 80's and is connected to a Tekmar mixing valve reset 228 controller also circa late 80's.
  • Jay_14
    Jay_14 Member Posts: 39
    Old RTUs
    Recommend contacting tekmar. A few old 2k RTUs are available.
    Jay Vath
    tekmar Control Systems
  • tim smith
    tim smith Member Posts: 2,886
    I think I may have one. Email me if you need. Tim
  • Rocky_3
    Rocky_3 Member Posts: 236
    Heatboy,
    I have a few 054's laying around if they will work they are yours.
    (907) 750-2798
    Rocky
  • heatboy_11
    heatboy_11 Member Posts: 6
    Thanks, Rocky, but.........
    .........they are 10K and these 304/305/307 RTUs were 2K. C-C-C-Cold there?
  • JJ_4
    JJ_4 Member Posts: 146
    2K Balco
    I think that any 2K balco sensor will work (as temp goes up resistance goes up). Here is one from the Kele catalog on line:
    http://www.kele.com/olcat/t1/10334.html
    The "type 78" is a 2K balco.
  • Rocky_3
    -19 last night
    with a high today expected between 0 and -10, with lows anywhere from -15 to -30 depending on what part of the valley you're in. I guess that's cold depending on your particular definition of cold. To me, cold starts at -30.
    Will be deep frying a turkey for Thanksgiving as long as its above -25. Hard to get the propane deep fryer to stay running if its too much below that. Been several Thanksgivings I couldn't do it because the propane wouldn't vaporize.
    Warm regards from chilly (not cold) Fairbanks,
    Rocky
  • Rocky_3
    Cut 80% of it off....
