Tekmar RTU Type 307..............hb
heatboy_11
Member Posts: 6
........have one somewhere on a shelf in the back room? This is circa late 80's and is connected to a Tekmar mixing valve reset 228 controller also circa late 80's.
Old RTUs
Recommend contacting tekmar. A few old 2k RTUs are available.
Jay Vath
tekmar Control Systems0 -
I think I may have one. Email me if you need. Tim
Heatboy,
I have a few 054's laying around if they will work they are yours.
(907) 750-2798
Rocky0 -
Thanks, Rocky, but.........
.........they are 10K and these 304/305/307 RTUs were 2K. C-C-C-Cold there?0 -
2K Balco
I think that any 2K balco sensor will work (as temp goes up resistance goes up). Here is one from the Kele catalog on line:
http://www.kele.com/olcat/t1/10334.html
The "type 78" is a 2K balco.0 -
-19 last night
with a high today expected between 0 and -10, with lows anywhere from -15 to -30 depending on what part of the valley you're in. I guess that's cold depending on your particular definition of cold. To me, cold starts at -30.
Will be deep frying a turkey for Thanksgiving as long as its above -25. Hard to get the propane deep fryer to stay running if its too much below that. Been several Thanksgivings I couldn't do it because the propane wouldn't vaporize.
Warm regards from chilly (not cold) Fairbanks,
Rocky0 -
Cut 80% of it off....
;-)0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 64 Pipe Deterioration
- 918 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
