Insulated Dropped Header
r. perry
r. perry Member Posts: 45
Billy, THANKS!! for the info and link. Beautiful work. I can only hope my attempts come out looking half as good as yours.
  • Billy_12
    Billy_12 Member Posts: 25
    Finished insulating the header and mains. Still waiting for some more reinforced tape for a few of the connections. I have to tap in some new vents and then I'm done :(
    There are no rads in my kitchen and downstairs bathroom so they tend to be colder spaces. Maybe I need to install a small hydronic/radiant system :)
  • Brad White_203
    Brad White_203 Member Posts: 506
    Snug as a Bug
    Nice job, Billy, I bet she purrs like a kitten.
    My only suggestion (only? eh, you know me), is the supports and that you use saddles to keep the insulation from crushing, but also, a nice but non-essential touch, is to brush insulation cement on the exposed pipe insulation ends. Just looks nicer and keeps fibers in place.
    Other than that, nice job!
    Brad
  • David Nadle
    David Nadle Member Posts: 624
    Looks great.
    Looks like a practiced hand at work. I started my insulation job at the boiler, so my first and worst tape joints are there, instead of some inconspicuous spot on the mains. Live and learn.
  • Nice Job!
    and why not just add steam radiators in those rooms? You can get them in different shapes and sizes.......
  • r. perry
    What is the material used as insulation? It almost looks like pre-formed plastic. I need to replace all the insulation on the lines in my basement and the material you used looks great. Does it have a name?? and how difficult/tricky is it to install? Thanks! Ray.
  • Marc_17
    Marc_17 Member Posts: 13
    Thank you for the compliments/suggestions. I haven't forgotten about the header support.
    Bathroom is no big deal to add a small rad, but the kitch has not 1" of wall space - its all cabinets. I have full access to the joists under the kitchen floor. I added an elec toe kick heater, but it falls short of heating the space (high ceilings), and it's sooo loud. Maybe I just want another heating project. Kitchen is about 13'w x 20'l x 12'h. I've thought of hydro/radiant, elec/radiant/ forced air, even maybe running radiant off the return water. I would say elec/radiant would be the most cost effective up front and the least labor (but who wants that?)
    Maybe I should post this question on a separate thread.
  • Marc_17
    Install was easy for me because there were no tight spots - everything was accessible. Pipe insulation was standard 1" compressed fiberglass. The fitting covers were these plastic pieces (pic attached). First I covered the straight runs. Then I wrapped the fittings with supplied loose insulation. Then cover that with the plastic covers. The covers fit over the 1" pipe insulation for a neat look. Seams and connections are sealed with reinforced white tape and a special plastic tape for the fittings. I purchased from State Supply. Here is the link:
    http://www.statesupply.com/displayCategory.do?Id=2061
