Anti - scald mixing valve
Norm Harvey
Norm Harvey Member Posts: 684
Personally, I like the honeywell thermostatic mixing valves
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=569&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Jim_167
    Jim_167 Member Posts: 11
    What are the " best " anti scald valves for output on water heater ? Anyone ever use elecronic controlled valves?
  • bruce_21
    bruce_21 Member Posts: 246
    pressure drop charts
    If you ask determinedly you can get the wholesaler or mfg rep to produce the pressure drop chart or curve for the valves you are considering and compare them. A lot more restriction is in there than you might think.
