Anti - scald mixing valve
Norm Harvey
Member Posts: 684
Personally, I like the honeywell thermostatic mixing valves
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=569&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
What are the " best " anti scald valves for output on water heater ? Anyone ever use elecronic controlled valves?0 -
pressure drop charts
If you ask determinedly you can get the wholesaler or mfg rep to produce the pressure drop chart or curve for the valves you are considering and compare them. A lot more restriction is in there than you might think.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
