when to braise?
Timco
Member Posts: 3,040
So under what conditions should one braise? System I am on has leaks in 2 braised connections and one major leak in a soldered fitting. I am considering just braising all of them. several connections made of braise and solder. Why both?
Tim
Tim
Just a guy running some pipes.
What size pipe ?
And what pressure and temp are they handling ? I'm guessing they tried to braze the soldered fitting because it was probably easier than pulling the fitting apart , cleaning it and resoldering .0 -
Maybe
Check out water in system, or is there antifreeze of some type. Seems like there may be a hidden issue. That could be why some joints are brazed. Or maybe the other guy just couldn't solder!0 -
2" & 3" ftgs, 20psi, 180*. Glycol. It would really suck to take apart these fittings, which are close spaced tees in a pic sec intersection.
TimJust a guy running some pipes.0 -
I've tried
the ol' flux , solder , flux , solder trick on those problem jobs . Never seems to work .
Will a braze joint hold in a dirty fitting ? The only brazing we do is on A/C lines , 3/4" maximum . Different scenerio but I had a leak on a 3 inch by 2 inch threaded tee in the middle of a primary secondary tree . Just had to bite the bullet and take it all apart . It actually went faster than I thought .
Good luck with this one Tim .0 -
cap
get a rosebud and some 15% sil-fos and cap all the joints.There was an error rendering this rich post.
Did you insert the glycol yourself? Could it not be blended properly? If to strong, it will add to your problems. Good Luck!0 -
ProPress
This is where ProPress fittings come in handy. Despite their cost, they don't leak when assembled correctly. You may be able to borrow or rent the tool and jaws.
Trying to braze over an uncleaned joint is a recipe for trouble. Just my humble opinion.
and maybe
a thermal expansion induced problem. The pipe needs to have some room to move if it sees wide temperature swings. Don't fasten it solid on al corners. Unistrut clamps with the flexible inserts may be the way to mount the assembly.
I'd cap it using a rosebud tip and some JW Harris Blockade. Blockade is a silicone based alloy material and is said to handle expansioin better then some of the other filler metals. It melts at a lower temperature than silflos and is very workable for capping joints.
The Harris website has some excellent info about solder and braze material and procedures.
Becareful torching on pipes with glycol, they can flame up on you. I'd isolate the section and flush it well with water.
Same flush after you braze at high temperatures as you end up with a bit of black flakes inside the copper. No need for that in the glycol.
hr
well, the safety silver is pretty expensive, but works very well by sitting right in the joint. The Blockade was very easy to use, flux was not an issue to use. Have to say, the Lennox CU rods are just as easy to use with proper technique. I like brazing, I must say...I would have used pro press, but there IS glycol in the system, you now....
p-press not
good that you stayed away from it
harris also has a silver bearing solder #8 that's very good0 -
ProPress and Glycol
Where does it say that ProPress fittings shouldn't be used in Glycol systems? Just curious...
ProPress
can be used on Glycol for heating and cooling systems up to 50% glycol mixture.
There have been some issues of a slight leak w/ ProPress and glycol, but I don't believe that it is a serious issue.
If you need to borrow a tool call Viega and ask your local District Manager if you can borrow a tool.
Warm Regards,
bb0 -
After the great propress debate of '08, I decided to stick with a joint that I make, and know will never leak, thus braze. Many customers do not trust pex, and propress seems less tested than pex. The braze is very permanent and I like that...controlling my own destiny. I was actually joking when I mentioned it, but I have chosen to trade speed for known methods of permanent fixes.
