Safety Valve installation...
I had the oil company replace the leaking pressure relief valve on my Utica steam boiler today. They used a Conbraco 13-101.
Somehow, using this just doesn't seem right to me. It is screwed in to a tap on the top of the boiler, pointing straight up. If I were to follow the instructions to test it, I'd presumably get a face full of steam.
They did the work while I was at the office, so I didn't get a chance to ask the technician about his choice.
I've attached a photo of the installation.
Am I nuts, or should I ask the company to send someone back to install a right angle safety valve and a piece of pipe so that the output points at the ground like it did before.
Thanks!
Pete Morenus
  • Timco
    Timco Member Posts: 3,040
    You test a relief valve with a cold boiler to ensure it is not stuck shut, but I do agree that a 90* valve is much safer. I see these often and they do meet code in my parts. I cannot imagine someone flipping the test arm with steam being made...seems like a bad design...
    Tim
    Just a guy running some pipes.
  • Agreed Tim
    The angle pattern (with proper discharge piping), seems much safer to me.
    Dave
  • I would pipe it down to the ground. When I bought my house last year, the pressure relief valve on the boiler was similar to yours, except it was aiming to the side. One day, in the kitchen I hear a loud steam relief sound from the basement. It was probably the pressure relief valve. Imagine someone was standing or walk by, they would have been burned. I went to Home Depot the next day to buy a long pipe so it's aiming to the ground now.
  • bob young
    bob young Member Posts: 2,177
    obsolete for fifty years
    that style has been illegal in nyc since the early sixties. we used to rip them out & replace by the dozens.
