Safety Valve installation...
Peter Morenus
Member Posts: 1
I had the oil company replace the leaking pressure relief valve on my Utica steam boiler today. They used a Conbraco 13-101.
Somehow, using this just doesn't seem right to me. It is screwed in to a tap on the top of the boiler, pointing straight up. If I were to follow the instructions to test it, I'd presumably get a face full of steam.
They did the work while I was at the office, so I didn't get a chance to ask the technician about his choice.
I've attached a photo of the installation.
Am I nuts, or should I ask the company to send someone back to install a right angle safety valve and a piece of pipe so that the output points at the ground like it did before.
Thanks!
Pete Morenus
Thanks!
Pete Morenus
You test a relief valve with a cold boiler to ensure it is not stuck shut, but I do agree that a 90* valve is much safer. I see these often and they do meet code in my parts. I cannot imagine someone flipping the test arm with steam being made...seems like a bad design...
TimJust a guy running some pipes.0 -
Agreed Tim
The angle pattern (with proper discharge piping), seems much safer to me.
Dave0 -
I would pipe it down to the ground. When I bought my house last year, the pressure relief valve on the boiler was similar to yours, except it was aiming to the side. One day, in the kitchen I hear a loud steam relief sound from the basement. It was probably the pressure relief valve. Imagine someone was standing or walk by, they would have been burned. I went to Home Depot the next day to buy a long pipe so it's aiming to the ground now.0 -
obsolete for fifty years
that style has been illegal in nyc since the early sixties. we used to rip them out & replace by the dozens.0
- 114 Geothermal
