Munchkin F10, but starts easily after reset
Chuck Lesker
Member Posts: 1
My Munchkin keeps going F10, which apparently means the flame failed to light for four tries. But when I reset it, it starts immediately and runs fine. Then it fails again the next time it has to start.
I cleaned the flame sensor earlier this fall.
Any suggestions appreciated.
check all the ground wires for tightness, did you clean the sensor with sandpaper by any chance. Sand isnt a very good conductor of heat that could be it.0 -
munchin f10
I had the same problem.. It turned out to be the air intake was being contaminated with the exhaust..I know the trouble shooting does not ention it, but that was the problem.0 -
munchin f10
I had the same problem.. It turned out to be the air intake was being contaminated with the exhaust..I know the trouble shooting guide does not mention it, but that was the problem.0 -
check sensor wiring at terminal, burner screws need to be clean and tight, scotchbrite sensor and cross your fingers.
Terry0
- 167 Indoor-Air Quality
