Munchkin F10, but starts easily after reset
My Munchkin keeps going F10, which apparently means the flame failed to light for four tries. But when I reset it, it starts immediately and runs fine. Then it fails again the next time it has to start.
I cleaned the flame sensor earlier this fall.
Any suggestions appreciated.
  • tom_49
    tom_49 Member Posts: 267
    check all the ground wires for tightness, did you clean the sensor with sandpaper by any chance. Sand isnt a very good conductor of heat that could be it.
  • bob_17
    bob_17 Member Posts: 14
    munchin f10
    I had the same problem.. It turned out to be the air intake was being contaminated with the exhaust..I know the trouble shooting does not ention it, but that was the problem.
  • bob_17
    munchin f10
    I had the same problem.. It turned out to be the air intake was being contaminated with the exhaust..I know the trouble shooting guide does not mention it, but that was the problem.
  • Kool Rod
    Kool Rod Member Posts: 175
    check sensor wiring at terminal, burner screws need to be clean and tight, scotchbrite sensor and cross your fingers.
    Terry
