Honeywell CT87K
Tom DeBrum
Member Posts: 18
Thank You for your responses,
Tom
Tom
Honeywell CT87K
Hi Everyone,Do you have to use a resister on taco zone valves when using a Honeywell CT87K T-stat,(non digital heat only.)
I'd appreciate any help
Thanks
Tom0 -
I don't thinl so. Did the TT come with one?0 -
Honeywell CT87K
I don't Know I did not install it ,couldn't find info at honeywells site.
Thanks
Tom0 -
No, you don't need a resistor.
The only purpose for the resistor was to prevent the digital display on the old T8400"s and T8775's from blanking out when the Taco valve opened. They also were used with certain oil primaries for the same reason. You don't need it for the CT 87. Just connect the wires, set the dip switches to the setting appropriate for your system.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
