Panels and manifold flow control
Pete M_2
Pete M_2 Member Posts: 18
Radiant panels have balancing valves built in. Do I need an expensive manifold that has flow meters and balancing valves or can I go with a simple copper manifold and do the balancing at the panel? There is a huge cost difference in manifolds.
