Panels and manifold flow control
Pete M_2
Member Posts: 18
Radiant panels have balancing valves built in. Do I need an expensive manifold that has flow meters and balancing valves or can I go with a simple copper manifold and do the balancing at the panel? There is a huge cost difference in manifolds.
I just used the copper...
ones for mine...kpc
balance
You can balance at each flow setter on most European panel rad.0 -
Just....
Don't forget some kind of by-pass for each manifold.(zone manifold)
If you're going to be running multi manifolds, and dead heading the flow, make sure the water can get "back" in the case that most are closed...while 1 other is calling.
My .02. Chris0
- 120 Geothermal
